RSView ME security code to PLC
AJZ
Jul 2003
Ontario
265
Is there a way to inform the PLC what security codes are active for the active user. I like the PLC to know if the current user has security code B assigned or not. Equipment used is a 1756-L61 with PV+ using RSView ME 4.0
I can't imagine why you would want to do this, as the HMI restrictions should prevent access to things in the PLC anyway, BUT you can try this...
1) Create a bunch of tags, that write to the PLC. (Has_Code_A, Has_Code_B, etc)
2) Create a Login Macro, and assign the tags in the Login Macro...
MACRO_LOGIN
1-- Tag: Has_Code_A Value (Expression): CurrentUserHasCode( A )
2-- Tag: Has_Code_B Value (Expression): CurrentUserHasCode( B )
etc.
Can anyone tell tell if there is a way to know who (Code letter) is logged in to the versa view. Thanks
3,019
Hi all Having trouble with password resetting. New customer wants a user name and password I had previously used. When I try to reset the...
2,520
I'm trying to setup a password protected screen in RSView Studio 4.0. What I want is to have a goto button on a non security screen that directs...
3,570
is there a way to show/hide buttons in rsview 32 based on the user's scurity settings? i'm reworking our hmi and learning how to use view at the...
3,856
Can anyone point me to some tips and tricks for getting the Windows based security on a PanelViewPlus to work properly. I configured the domain...
8,799
