RSView SE Alarming
modicon2
Guest
M
I'm running RSViewSE Server on a HMI Server PC located in a rack room.
I've got 2 PCs running RSViewSE Client in the control room.
(Version 3.10.00) If more info is required, please let me know.
The alarm bell only sounds on the HMI Server box.
I need audible alarms on the operator consoles (RSView Client) machines.
The little bit of tech help I've received led me in the direction of using an PLC output to external Bell method or using VBcode to play sound on Client Stations (but unable to provide any VBcode).
Anybody else having this problem?
Any help/suggestion/advice would be greatly appreciated!!
I'm still confused on why it is so difficult to get an Operator Station to have audible alarms.
Thanks!!!
You could add a MS MediaPlayer Component into the project then start it with VB. This would let you play a different mp3 depending on the alarm.
Has anyone done any conditional programming with RSVIEW Studio alarming such that if alarms existed, and were unacknowledged, a particular bit...
1,920
Hi Guys, When i start my RSView application client I recieve error maximum Alarm fault exceeded(500) None of the active alarms appear in the...
1,505
Hey folks! In RSView Studio, a colleague of mine developed an ME application for a PanelView Plus 1250. Everything appears to be running fine...
2,398
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
327
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
270
