RSView Studio 5.0, PanelView 1000 Plus
Patrick
Apr 2007
Washington State
96
RSView Studio 5.0, PanelView 1000 Plus. The system was installed about a year ago. I have a password that works on the panelview. When I run the screens from RSView test application, the password doesn’t work. Is this normal?
I can't recall the reason why but.
If you look at the users on the computer you are testing with you will probably find that the account you are trying to log in with is corrupted and looks like a big long serial number.
Delete this account and recreate the user you are trying to use. You should be good then.
This is common when you restore an .apa file on a different pc than the one that developed the application. RSView ME uses the user accounts on your pc I believe.
RSL
Thank you for the response. Not sure if I'm looking in the right place. I see several names with passwords. Maybe i'll wait till the AB rep shows up next week. I was just curious.
Thank you
Pat
RSL
Correct - that is what is happening.
I need a multistate indicator with a trigger type LSB that will span four integers. So, I created it with the connection tag "MESSAGE" assigned...
4,080
Hello, I just received a PanelView application in the form of a .PVA file, and would like to take a look at it. I have RSView Studio installed...
5,059
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,330
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,037
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,519
