RsView Studio can generate Reports of in Excel?
Hello Manasi;
RSView Studio is used to develop applications for RSView SE or ME.
Here is what the RSView SE muser manual says about Data log storage:
Data log storage formats
Logged data is stored in either an internal file set or in an ODBC-compliant database.
File sets store tag values in proprietary-format files. You cannot view the contents of these file sets, except in trends. File sets provide faster performance for historical trends than an ODBC database.
If you log tag values to an ODBC database, you can view the data in trends, or use thirdparty, ODBC-compliant tools to analyze and create reports from the data. If the ODBC database becomes inaccessible, RSView logs the data to backup files in proprietary format.
To use data in multiple formats, define multiple data log models for the same tags.
Basically, it comes back to what we do now with RSView 32: Use an Access database to log the data from RSView through ODBC, use a pivot file in Excel to create a report based on the records available in the Access database and update the data values:
http://www.lacher.com/toc/tutpiv.htm
Hope this helps,
Daniel Chartier
Hi Daniel,
Thankyou for the Pivot Table tutorial link. Very informative.
Best Regards
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,327
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,034
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,516
I have an RSView SE 3.0 distributed application running on a Client/Server. Can I use FTView 7.0 to develop some new screens and or modify...
3,912
Hello I am trying to get certain screen components to be visible unless an h/o/a switch is turned to manual I:0/8 being the input for the...
1,346
