RSView Studio ME Trend Object Question
jstolaruk
Dec 2004
Detroit, SE Michigan
3,911
It would be nice to display some static X-Y data on this PV+ project I'm working on. Can a trend object be setup to do this? If so, got some pointers to get started? I can't see how it can be done.
Thanks in advance. Jeff
I looked into this a while ago and it's not really possible.
The X-Y form of the PV+ trend is still time-based; it polls X and Y and just replaces Time with the value of X. X is still polled on a time basis. You could write a little routine to "meter out" the X and Y values to the PV+, but that's time consuming while drawing the graph. There also isn't a good way to re-draw the plot on command.
I ended up doing a brute-force method as well, with 100 little square dots with position animation. It worked OK for my application, which was a temperature profile.
Thanks Ken, that was my method also.
For anyone else interested, I changed the "Chart Update Mode" to "On Change", set the X axis to pen #1 (my X data), blanked pen #1, metered out the XY data at a set rate, and then adjusted the width of the display to correspond to the total number of readings times the increment I released them at.
I guess it wouldn't take a lot to create an ActiveX control to do what I want but this is just one small app and the rest of the cell is waiting for me.
-Jeff
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,327
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,034
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,516
I have an RSView SE 3.0 distributed application running on a Client/Server. Can I use FTView 7.0 to develop some new screens and or modify...
3,912
Hello I am trying to get certain screen components to be visible unless an h/o/a switch is turned to manual I:0/8 being the input for the...
1,346
