RSView Studio ME v4.00 fails to create new application
bomb3rman
May 2007
Jln Berakas
Hi there,
I've been trying to create a new application on RSView Studio ME, but everytime I click on 'Create', the whole program would close itself down (no message, not running on background). I've tried to do a fresh installation for it and RSLinx, but that didn't help. Opening any existing applications are fine. Any ideas? Thanks.
I had exactly same problem about 10 months ago, but with Visual Studio not with RSView Studio ( some similarity :))
I fought for about one week without success.I gave up and reinstalled Windows. Worked like a charm after that.
But maybe somebody has a better solution.
Yes the same. By the way do you have a RSView32 installation if so uninstall it first, then un install studio. follow the technet note in rockwellsoftware site" clean un install RSView Studio". if possible clean the registry(It's a real mess). then install first the studio followed by the RSView 32. If nothing works then you have to re-install windows. by the way there were some patches did you install them? hope this would solve your problem.
Thanks for the reply guys... I don't have RSView32, I have done the uninstalling as mentioned in the TechNotes, but it is still the same. The Rockwell support guy has not heard of this before... and the only solution left is to re-format the computer, which I am really reluctant to do.
Hi
Actually new apllication is creating but it is hiding by the the system, I don,t know the exact tool on toolbar because since last so many days I had,t worked on it, you just click on left hand side tool of runtime tool one by one yr problem will definatly solve
What is the runtime tool? Is that the 'Test Application' button from the Standard toolbar? It's grayed out, can't click on it when the application is creating... Please reply, thanks...
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,325
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,018
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,514
I have an RSView SE 3.0 distributed application running on a Client/Server. Can I use FTView 7.0 to develop some new screens and or modify...
3,909
Hello I am trying to get certain screen components to be visible unless an h/o/a switch is turned to manual I:0/8 being the input for the...
1,345
