RSView Studio SE Displays variables
awnet
Jun 2007
Viareggio
44
Hi!
I have a problem with the displays of my project in RSView Studio SE. Colud you tell me how to access the variables of one display from another display. I put for example a string public in a display but I can't refer from another display. o_O
Thanks.
bye
Michele
The easiest way may be is to make variable or tag for your display variable. then you can use it everywhere.
Every component in a display have unique name called COMMON. you can use it.
Sorry but I can't understood very well. What do you mean with the word COMMON I can't find in the suggest in the list suggests that appear when you write code.
Help.Please
Tags can be referenced from any display.
If you are talking about a VBA Variable, you need to enumerate the list of open displays, find the right one, get a handle to the object, and then use it's properties. If a display is not open, then you simply cannot access a VBA variable.
See Rockwell tech note A31737385 for an example.
I created a project, then backed up the application and transferred it to a laptop for DL to the PV+. In the process of testing the program I of...
4,432
Hello to all the knowledgeable people inside the computer screen, my problem at the moment is like the title says, l can't open projects in...
1,329
Hi Working with some project guys who have replaced a controllogix processor previously using RSLogix 5000 V11 for a controllogix 5588E using...
4,037
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,518
I have an RSView SE 3.0 distributed application running on a Client/Server. Can I use FTView 7.0 to develop some new screens and or modify...
3,915
