RSView & Visual Logic Controller
skalt
Jul 2003
43
SInce i got no answers this week end I am posting this again....
For several days now I have been attempting to create a valid tag in RSView32 to communicate with a OPC server from SteepleChase (VisualLogic). The industrial PC running the SteepleChase software is not running RSLinx. When I use OPC Test Cleint from RSLinx I am able to monitor the data in real time across the peer-to-peer Ethernet. However, any tag I configure in RSView shows to be invalid and will not read the data.
Any ideas from anyone would certianly help!
The most common thing in RSView32 is to use RSLinx as an "in-process OPC server" on the same PC as RSView.
Your posting suggested that the VLC OPC server is on a different PC than RSView32. That means that your data source in RSView32 must be configured as a "Remote OPC Server".
Post some info about how you configured your OPC source in RSView32 and there might be more info forthcoming. I don't use VLC but I've done remote Kepware servers with RSView32.
hi skalt
Another point to consider is the version of RSView32. if you need opc
2.0 compliance then Rsview32 must be 6.4 or above. Version 6.3.17 is not 2.0 compliant. You may have to look into using the kepware opc software to give the connection that you want. Went down this scenario trying to connect to omron plc'c and ended up using kepware. It works really well.
Post some more details and will try to help
kevin
You are correct. It is configured as a remote opc server
Node Setup
Server name= \\name_of_remote_pc
we have also tried \\name_of_remote_pc\visuallogiccontroller
and
\\name_of_remote_pc\Steeple_Chase_Software.visuallogiccontroller.2
path is left blank in hopes that we could browse the multitude of tags from vlc
Kevin,
The version of RSView is 6.4.... we have already checked that out.
Stan
Hello everyone, I was wondering if it would be possible to execute programs written in other languages on a panelview plus. Say I have visual c++...
1,663
Hi , I want to write a value to a tag in RSView SE from Visual Basic. Tg type is String and integers and is a memeory tag. if you have any code...
8,603
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
301
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
258
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
811
