RSView Works, RSLinx, RSLogix 500 Emulator
tayto
Dec 2010
Ireland
Hi Everyone
This is my first post, I will try to give you as much information as i can, but am not used to rockwell products. I have an application in RSView 32 works 7.50.00(CPR 9 SR 1), I have a program in RSLogix 500 Pro 8.10.00(CPR9). I am running the program in an emulator and i want to talk to the rsview. I created a test page in Rsview and while toggling the value in the PLC(Emulator) would like to see it update in RSview.
I have created a node called test and pointed it to local RSLinx OPC Server and i created a tag which i wanted to point to a bit in PLC program when toggle bit see change on screen, however i cannot see bit in online browse folder, and when i hardcode it in it doesnt work either
I have attached some bitmaps of what I have done so far.
Any help is appreciated, sorry if i seemed confused due to lack of rockwell knowledge
sure, basically when i configured the Emulator driver, i seen that it used DH485 therefore i just used DH485 in RSView and was able to browse my tags
We have an older laptop here at work that has RSView Studio on it that isn't used for anything. They only use Red Lion HMI's now. I was thinking...
1,516
what's the difference between Rsview ME and RSVIEW32 works and can'i migrate a RSVIEW ME project to FActoryTalk !!thnx....
1,571
For this particular client we have many RSView32 Runtime licenses and each one is local to the individual computers. We have one RSView32 Works...
2,468
I have the VB code: Private Sub NumericInput5_Change() Dim Logged_Message As String Set oPC = Me.FindElement(Me.ActiveElement.Name) Park_Veh...
1,327
Hi people thanks in advance for your replies. I have a process which takes 3 hours for the product to get from start to finish. If there is a...
3,740
