RSView32 and RSLinx Pro
I did everything suggested but I cannot browse my tags and I keep getting errors in monitor. I am version 9 of RSLogix and I tried going online and was unsuccessful. I have included screenshots. I can browse in RSWho and I can ping the IP configured for the ENBT. (I have no need for remote activity, so OPC Server is "In-Process" and Topic is "Local")
I am using RSView32 as OPC client v 6.30.17 and RSLinx Professional as OPC Server v 2.40.01. I cannot connect my client to the server, hence I am unable to browse my tags and view data in display. Everything is on one XP pro machine.
I configured driver (able to browse I/Os), created Topic and pointed to Controllogix controller.
I created Node: RSLinx OPC Server (local), enabled, left Address Path blank. My tag monitor is returning errors.
I was told to copy DE/ OPC Link in RSLinx to RSView32 but I am not sure where to paste it or where I am copying it to.
thats a problem I have thousand times.
The Solution is to use the RSLogix Tag Import Tool
Take a look at the Picture !!!!
This tool comes with RSView 32 !
This is how to get your Tags into RSView:
Step 1: Save your RSlogix 5000 file as a .l5k file !!!!
Step 2: Close RSLogix - Open The Logix 5000 Tag Import Tool
Step 3: Combo Box --> For RSView 32 7.00 or later versions
Step 4: Node Name --> The Name of your DDE Connexion in RSLinx
Step 5: Tag file Name --> Your saved .L5K file
Step 6: Select the Tags you want to use in your RSView Application
Step 7: Add RSLinx Topic to Tag Adress - Same Name as in Step 4
Step 8: OK --> The converts your Tags now to a .CSV File
Step 9: Close the tool
Step 10: Open RSView 32 --> Open your Application
Step 11: Project --> Import Export Wizard
Step 12: Combo Box --> Import RSView CSV Files
Step 13: Browse for your .CSV File --> Next
Step 14: Next
Step 15: Next
Step 16: Finsh
There maybe other ways to rome but I use this for last projects I made and it worked allways fine.
Bei Fragen...fragen
Viele Grüsse
Bernd
:hmmm:can anyone help with what should be the version of rslinx classic communication for rsview32 v 7.10
1,564
Hi all, i'm new on this forum. I have some problems with the communication with rsview32. The version is rsview32 7.10 and rslinx gateway. I am...
2,788
Hey guys, I know this topic has been beaten down in the past (as per the number of threads after doing a search), but I wanted to confirm...
3,750
I am trying to monitor coms from multiple rslinx opc/dde nodes in rsview32. I have tried different ways to accomplish this, to no avail. I assume...
2,503
Does anybody have experience to install RSView32 in combination with RSLinx on a Windows XP embedded OS ? It will communicate to a Compact Logix...
4,152
