RsView32 and RsLogix 5000 Emu Connection
gyilmaza
Jul 2010
Turkiye
Hi everyone,
I need some help about connection of RsView32 and RsLogix 5000 Emu. I used RsView ME til now and I have to use RsView32 in my new job. I use RsLogix 5000 Emu and I didnt connect Emu to RsView32.I tried everything but couldnt find the solution.
In RSView 32 what is set up in Channels,
What is setup in Nodes,
In RSLinx What drivers do you have,
Are you using OPC and if so what settings
Maybe some screen shots will help us help you
Welcome to the forum
I take some printscreen and maybe after that you can help me Gil.
First I get in the Channel menu this window I get :
http://img580.imageshack.us/i/41737474.jpg/
Whatever network type I choose in , I choose AB VBP-1 in Primary Communication Driver tab.
http://img823.imageshack.us/i/98626851.jpg/
http://img237.imageshack.us/i/17257555.jpg/
At the end this message appears.
http://img268.imageshack.us/i/98043927.jpg/
Those images are OK ,
but
The top 2 image links don't work and I need to see Nodes and Channels
When you post it is possible to attach JPG directly to your post
check out < Go Advanced > button below.
Hello, gyilmaza, and welcome to the Forum !
What you have illustrated is called a "Direct Driver" in RSView32. This is the oldest driver configuration method and is meant for PLC-2, PLC-3, PLC-5, and SLC-500 controllers. While RSView32 does not prevent you from selecting drivers and devices that point to ControlLogix family controllers, you can see that at the end it will not work with ControlLogix.
RSView32 and ControlLogix can only communicate using OPC. You will need one of the licensed versions of RSLinx Classic; OEM, Professional, or Gateway.
In RSView32, leave the Channel configuration empty.
Configure an OPC Topic in RSLinx Classic that points to the Emulator.
Configure RSView32 to use RSLinx Classic as an OPC Server in the Nodes configuration. Leave the path to the OPC Server blank so that you can use the OPC Browser later while browsing the tag database.
Hello guys..!
I am facing the same problem. And I followed the steps as suggested by Ken but in
Tag database> OPC Adress Browser I am get the message 'Connection to server failed'
what could have gone wrong..?
I have setup an RSLogix 5000 FBD program to run on RSLogix Emulate 5000 and built a corresponding HMI on RSView32 which is linked by an OPC...
2,125
hi i have project with rslogix 5000,i did the first step that is the import tagdatabase from rslogix 5000 to rsview ,but i have problem in the...
6,366
Anyone know how to connect rsview to rslogix emulate? I know you cant download a program to emulate remote from rslogix on another computer but...
8,723
Is anybody give the way to connect rsview32 to rslogix5000 through rslinx classic........
4,209
I have rsview32 showwork 2hrs demo software and Rslogix500 Allen Bradely starter for 10pt microplogix 1000 kit . I make a simple on/ of ladder...
5,751
