Rsview32 Event run at startup
There isn't a default start up macro, make one and name it what ever you want. I call mine StartUp. Then under systems settings open start up. Then select the start up tab. Put a check mark in the start up macro box and then enter the name of your start up macro. Place the commands you wish to use at start up in the macro.
I strongly recommend using a start up macro as it lets you start multiple event and derived tag files with different evaluation parameters, start multiple logs, and pre-load and cache displays.
There is a System Startup command that acts like another graphic screen. You can set a bunch of preferences on startup, and also set the first graphic screen to run. I have used the System Startup command to load a dummy first screen ("0_Start" in the picture), which in turn loads events, or may call a Startup Macro, or perform other startup tasks, then Aborts itself, then jumps to the real Main screen.
Hi everyone, I'm Lelis and i have to make an event run every like 5-10 minutes. The action is: AppStart "C:\Folhas de Marcha\Fonte - Folha de...
1,507
If an RSView32 works project (version 7.5) consists of several screens, named for example: Screen1 Screen2 Screen3 . . . . Screen-N What is...
1,486
Hi, can someone advise the best way to create an "event" log in RSView32. there appears to be built in ones but im not sure they will have the...
2,234
Hi, I have facing a problem when developing RSView32 that connecting to AB PLC5. May be somebody in this forum knows how to create a sequence of...
3,733
How do i execute a event every 250 ms. I cant use the system timer because it only updates every 1 sec.
3,262
