DrewSanders
This is a total novice question... hopefully I can describe clearly.
We have a Windows 7 machine with an Allen Bradley 1784-PKTX Card installed. We have the device drivers installed and all looks good in Windows Device Manager.
We have an existing RSView32 project that we are trying to run on this system (it currently runs fine on another virtually identical machine running windows XP). When I go into the project and look under System - Channel. Channel 1 is set for DH+ but the Primary Communications Driver is "none loaded" and the drop-down has no driver loaded. This should have an AB_KT-1driver available to select but does not.... what I am not clear on, is how do you get the AB_KT-1 driver to appear here?
Thanks for your help!
