RSView32 Runtime with 1756 L55M14 Controller
RZR
Mar 2011
Iraq
20
Hello everyone,
we have Allen Bradley Controllogix 5555 controller type 1756 L55M14 and Ethernet module 1756 ENBT.
The controller programmed using RSLogix5000 V13 and a project created for HMI using RSView32 works 1500 Revision 7.10.00.
I want to connect a PC through Ethernet module 1756 ENBT to the 1756 L55M14 controller and use it as HMI and purchase RSview32 Runtime 1500 to visualize the project that created by RSView32 Works revision 7.10.00. I need to know what software in addition to RSview 32 runtime do I need to purchase and I will be thankful if some one can answer my below questions:
1- Do I need RSLinx. If yes what type of RSLinx should I buy.
2- Do I need RSNetWorx for EtherNet/IP in order to built communication between Ethernet module and PC.
3- Can I use the project that created by RSView 32 Works revision 7.10.00 with a newer revision of RSView 32 Runtime.
And finally any idea about how much each RSView32 Runtime 1500, RSLinx and RSNetworx for ethernet will cost.
Thanks.
I am Using RSView 32 V6.30.17 in Windows 2000 in AB HMI. When i go to Login Page a window popup saying 'ActiveX component Can't Create Object'...
1,993
hello, I have recently been experiencing a problem with RSView32 Runtime where communication loss occurs temporarily resulting in tag values to...
2,781
I'm sure that many RSView users have had this problem. You develop an application using RSView32 Works. The application is deployed on a machine...
5,201
Hi, I have an RSView32 program which seems to work ok but when I stop the runtime an error something like 'Write to tag xxx has failed - could...
1,684
Hi, I have some Allen Bradley PLC/RSView32 modifications to do for a client in Saudi Arabia. I don't have much experience with Allen Bradley but...
2,540
