Hi was wondering if you could help. We have a machine controlled by a Allen Bradley SLC 500 connected serially to a RSView32 V6.3 Scada system (on a windows NT Platform).
When we do maintenance we power down the machine and when finished we power back up again. However, the other day the comms didn't start up. Initially we thought it was RSlinx not seening the SLC but that was OK and we double checked the Runtime config file and that referenced the correct DF1 protocol etc.
The error that we are getting is a Popup with title Synchronization Error Max tag limit exceeded. Inside the popup it states a synchronisation error with tags and then lists the tags. The user then has an option of Continuing or Loading Project eitherway (without Sync)
One thing I did notice, that on startup of the machine (RSView32 Runtime initaited straight away on machine startup), the the SLC never initited comms with the screen (no led flashing on PLC) and it was necessary to start RSlinx and the Led then flashed. Even though we could now see plc, when RSView32 was relaunched there was still no comms. Wondering if anyone has encountered this problem?
Appreciate any help. Thanks - Rpax
