Failure importing RSView32 into FTView SE
Felipe_Br
Nov 2023
Goiás
I'm importing an RSView32 project into FTView SE. I'm using Legacy Tag Database Conversion on a virtual machine with Windows XP, I did the first step by exporting the legacy database, but when I copy the files to the machine with Windows 64 bits this message appears:
"Create new format(FactoryTalk View v6.10 or later) tag database with 'Legacy Tag Database Conversion' utility.
This log file can be found at 'C:\Users\Felipe.Goncalves\Documents\11072023_135514_Legacy_Tag_Database_Conversion_Import.LOG'
Creating new format tag database for the following 0 projects has been done successfully. Now you can freely
open these projects with FactoryTalk View 6.10.
Creating new format tag database for the following 1 projects failed.
C:\Documents and Settings\All Users\Documentos\RSView Enterprise\SE\HMI Projects\Supervisorio\supervisor.rsv - Possible root cause is importing csv file to sql database failed. The csv file is corrupted.
Creating new format tag database for the following 0 projects succeeded but with exception."
can you help me?
Hey all, I had a gif image which I saved as a jpg image, since Factory Talk doesn't seem to like gif. When I try to import through "graphics >...
4,226
97
I used vmware converter to clone and backup a physical pc FT View client and now after removing vcenter converter and rebooting I am getting a...
71
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
111
Wizards, It has been a few, but you all have always done me well. I have acquired a 1769-L33ER and want to use it as my collection PLC to...
519
