RTC:0/BL vs S:5/11 (Micrologix 1100)
wlr3m4
Oct 2017
Saint Louis
28
I'm looking to add some low Battery Status Alarms to a set of PLCs (Mostly RSLOGIX500 based). I noticed there were two possible alarms for low battery, RTC:0/BL & S:5/11.
Is there a real difference between the two?
Welcome to the forum
The RTC is a Real Time Clock module and not on all PLC's the S:/5/11 is for the main cpu/plc and thats is the one you should use or the one I have used in the past and seamed to work fine
This is a weird one. I vaguely remember reading something here about a firmware issue but I can't find the post. I'm looking at this tiny...
2,314
I'm using a Micrologix 1100 with Logix 500 software. I've added several lines of logic to an existing program where I'm trying to use the RTC to...
2,985
We have a system with a Micrologix 1100 in the field. Lately it's been driving me nuts and AB has been unable to help. The customer will call and...
2,663
Hi, I have successfully got my system to do the following: 1. write the RTC hours, minutes and seconds to 3 integer files every 250 mS. 2...
2,113
