RTS vs RPI
Trank
Jul 2006
Taiwan
In ControlLogix 5000, the AI module resets the RPI timer each time an RTS transfer occurs. What is the purpose for RPI timer be reset by RTS? If RPI will not be reset, what will happen? If RPI=RTS, RPI timer will expire before reset by RTS, or RPI timer will never expired? If RPI will never expire, does RPI multicast exist? It would be highly appreciated if someone could asnwer this question.
RPI - The amount of time (in milliseconds) between updates of data from the remote controller. This value is scaled as a real value from the microseconds stored in the controller. The local controller will receive data at least this fast.
RTS - A programmed interval at which updated information is supplied to the processor. It is a method by which data is gathered, at precise intervals, for use by the processor.
What this means is that the RPI is maximum frequency that data will be gathered from the remote controller. My understanding is that the RTS can trigger the process to gather that information more frequently thus reset the RPI timer.
Greetings to all ... I had an exceptionally bright and highly motivated student in one of my ControlLogix PID classes the other day ... this...
24
19,684
Hello. Why is my RSLogix 5000 start in grace period mode, even though I have a valid license? I also think I have a decently recent FT Activation...
102
94
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
352
AssetCentre Client loads correctly on the server, but when going through another machine the client never presents a splash screen; however, it...
157
