RTU Monitor Ethernet Radio status
mak07plc
Oct 2003
Fort Smith, Arkansas
Could anyone help on how to monitor status of a radio. There is no status bit available from the MDS iNET 900 Radio, we are using to make our wireless network, to tell the PLC (micrologix 1500) about its status, whether the radio link is good or communication has been interrupted.
I tried S:33/4 status bit, but it didn't seem to work..
Asmat
I don't think that you can since the i900 is strictly an Ethernet media. It doesn't particularly have anything to do with any brand of PLC or computer. This is almost the same scenario is trying to read the status of an LED out of a cheap 100BT hub from an Ethernet device.
The above is not necessary true for all radios. Data-Linc makes an integrated Ethernet radio for the SLC500 chasis. Here, they may provide some feedback for what you just described. By the way, how do you like those i900 bridges?
I am in the market for a hardware/software toolset to be able to monitor RS485 traffic in a Modbus RTU (RS485) setup which involves one master and...
10,557
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
52
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
233
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
273
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
119
