Hello everyone, is it possible to run several parameter sets of a parameter set
type automatically - one after the other with an individual time period? When
using the parameter set control, only one parameter set can be written into the
PLC at a time... The time period itself should be a variable of the parameter set,
i.e. it should be set individually for each parameter set.
Does anyone know further?
My main problem is that I don't know how to access e.g. adress the individual
parameter sets that were created via the control?
I use WinCC Unified, V18.
Thank you so much!!!
Kind regards.
Kind regards.
