Can a PanelView 1500 Plus Run multiple programs?
boozelclark
Jul 2010
Johannesburg
I have two PanelView 1500 Plus HMI's next to each other both communication to different PLC's. If i copied the program from the one onto the other could the one run two programs at once or does Factory Talk only allow you to run one? could i run two instances of factoryTalk?
Thanks for any help
No, you can't... only one runtime project can be open at any time.
- [FONT=comic sans ms,sans-serif]fuzzy logic[/FONT]
85
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
449
Hi guys. Currently working on a project that requires a Panelview Plus 1500 to read a CSV File (recipe) from a network drive. The issue I have...
1,062
Hi, guys, how’s going? I added one “Trend Object” on screen A in PanelView Plus 1500. Then configured “Refresh Rate”, “Buffer” ……and set up...
1,913
Good morning, I am onsite at a customer. They have a panel view plus 1500 that does not light up. The screen is always black. I am not very...
5,573
