Panelview Plus 1500 on Workgroup vs Domain
Nole
Jan 2016
New Brunswick
Hi guys. Currently working on a project that requires a Panelview Plus 1500 to read a CSV File (recipe) from a network drive.
The issue I have come across is that the customer thought the Automation Network was on a Domain, but is actually just a Workgroup. Because of this, the PV is unable to login to the network in order to access the network folder that contains the recipes.
Is there a way to add the PV on to the Workgroup so that it can access the network drive?
Thanks.
82
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
449
Hi, guys, how’s going? I added one “Trend Object” on screen A in PanelView Plus 1500. Then configured “Refresh Rate”, “Buffer” ……and set up...
1,913
Good morning, I am onsite at a customer. They have a panel view plus 1500 that does not light up. The screen is always black. I am not very...
5,571
I have a panel view plus that boots up with 40 EXE error (missing OP or corrupted) Is there a source where I can re installed the OP? If so, can i...
1,188
