Running a Beckhoff PLC as a VM?
riahc3
Jul 2012
Somewhere
Hello
Beckhoff used to have a Windows CE VM where it was possible to run TwinCAT and run tests but it only ran on Virtual PC.
Is there something for VMWare Workstation, VirtualBox, or Hyper-V? Thank you
I am note sure do I understand your question right but are you trying to run your plc program in your computer? If you are using tC3 you don't need anything special. Just set your target system to "Local" activate configuration and run your program.
I want to run Windows CE in a VM and run TwinCAT on it as well. Just like I would in production.
Like i said. You can run and test your program in your computer without virtual machine even your target system will be WinCe. Just open your plc project, set target system to "local", disable I/O's on device tree, activate configuration and turn your twin cat to run mode. It runs exactly the same way as it runs in your target device.
Yeah, as Mara is saying, when you run it as local, it runs as a VM with the same OS it would use on the target PLC. There is no way to test more thoroughly besides actually running it on the PLC.
This is not the same thing.
In a VM, I need the AMS ID. In a VM, I need to install the correct libraries I need. etc.
Thats why I want to run a VM with Windows CE and TwinCAT.
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
144
How to fix if appears code “$115 plc-restart running” on the screen OP17
250
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
350
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
107
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
99
