Running a CompactLogix program with Emulate 5000
rexcramer
Oct 2013
Michigan
34
Good afternoon.
I have a CompactLogix program that I am trying to run with an Emulate5000 controller. The program was written with a 1769-L33ER controller and has only remote IO controlled via Ethernet.
I can not change the slot # assigned to the L33 controller, and when I try to change the controller to an Emulate 5000 controller I get a Fatal Application Error and crash RSLogix 5000.
Is there a way to change the controller to an Emulate controller, or do I have to rewrite the program with the Emulator controller and simulated IO from the beginning?
Shouldn't have to write from scratch
I just grabbed a random compactlogix program that is from a running machine. I changed it to the "Emulator RSLogix Emulate 5000 Controller" and it did the change without any errors.
Not sure what is wrong. I guess more details would be needed.
rexcramer said:
...I can not change the slot # assigned to the L33 controller, and when I try to change the controller to an Emulate 5000 controller I get a Fatal Application Error and crash RSLogix 5000...
You have given specific details for the error message you are getting, but this is possibly relavent...
36238 - RSLogix Emulate 5000: Internal Error! Failed to install RSLogix Emulate 5000 in slot!
Access Level: TechConnect
Regards,
George
You have not given specific details for the error message you are getting, but this is possibly relavent...
Regards,
George
LATE EDIT: reason: I'm dumb
Hi all, Got a call from a client just now, apparently his remote well site stopped working so he has it in hand. He sent me photos of the PLC...
3,686
Good Morning , I would like to install an extra 1734-OA4 on a I/O expansion ( Ethernet ) but I don't want to take the CompactLogix out of...
1,744
I have a system with L35E and a couple of DI/DO AI/AO. The system was installed and running for 1 year now. At some point last week, none of the...
2,231
I am trying to upload a customer's L23 program to make some changes, but continually get this error when it gets to the "Uploading Modules"...
25
13,713
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
181
