Running Access macro from FactoryTalk
dswift008
Oct 2012
NY
We are updating a clients system from RSView to FactoryTalk SE.
I am a VB programmer that is helping our FactoryTalk person work through this.
In the RSView system there is VB code that runs triggered by an event that we need to duplicate in FactoryTalk SE.
The VB code calls a macro in Microsoft Access that prints a report.
This has lead to some questions:
1) We now need to run the VB Code from the client and have the Access database on the server. Is this possible?
2) If no one is logged into the server will the marco still run?
Macros on SE run on the client, not the server. Also the screen has to be running. Yes this can be done.
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
136
How to fix if appears code “$115 plc-restart running” on the screen OP17
248
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
341
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
94
