Running FESTO FPC-405 software on WinME
simplelogix
Sep 2003
Auckland
31
Hi Control Engineers,
I have a pc running WinMe OS. I got hold of a 2nd hand FESTO FPC-405 plc which runs its software on MS-DOS. (I dont know what version of MS-DOS). The software also runs on my pc with WinME and I can write code. But when compiling, it gives me an error message saying, "Incorrect MS-DOS version". And then the PC just hangs there!
Does anyone know how I can get around this without actually going out and buying WinXP?
Thanks for all your help.
Regards
simplelogix
My preference when working with dos software is to install a dual boot with a 600Mb dos partition and install dos & win 3.1 for ease of file handling.
I have dos, w2k & xp for watching DVD's and other tarty stuff.
However ....
If your program will fit on a floppy, then copy it to a floppy.
Make a dos boot disk and reboot your pc from the dos boot disk. Remove the boot disk and then run the program floppy. Not the best way, but the cheapest.
Cheers,
F
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
164
How to fix if appears code “$115 plc-restart running” on the screen OP17
269
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
117
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
105
