running light
running ligt is like a billboard that have a lot of LED as output to form a shape, wording, craft, image and so on.. just like the numbering count down for traffic light..
Adik Hadi,
Search for "LED Chasers" in your favourite search engine - may be google. You will hit hundreds of links. That would be a cheaper option rather to invest in PLC for this app. Unless you plan to run heavy wattage lights.
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
165
How to fix if appears code “$115 plc-restart running” on the screen OP17
269
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
117
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
105
