Running Sinamics G120 Drive from BOP-2
kArTmAN
Sep 2016
Dhaka
Today I have installed a Sinamics G120 250kW Drive(order no: 6SL3224-0XE42-0UA0), communication is via profibus DP from S7-300 PLC. When i start the motor from HMI, Motor doesn't rotate. In STARTER, i can see current is drawing(about 140A). Speed SP=0. Maybe frequency Ref is not coming...ZZzzz
Later i tried from BOP-2 panel (Hand Auto Mode) setting Speed SP. But same response here as well.
As i have parameterized the drive for freq/start-stop command from profibus, can BOP-2 run whenever i want in HAND Auto Mode???Or BOP-2 commands are ignored here??.........
Note: Before parameterizing, I have run the motor with BOP-2. Perfect it was then.
I have no experience with Eaton HMIs. I downloaded the Galileo software and I am trying to get the file on a HMI (XV-102-H3-70twrl-10) to modify a...
148
How to fix if appears code “$115 plc-restart running” on the screen OP17
253
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
357
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
111
A new point I/O rack is to be hooked up with the running PLC. In point I/O, it is supposed to be the OA4 card to be installed as per the...
100
