RX Logix 5000 plc with ASCII communication
onlybala
Aug 2017
Bangalore
Hi Friends,
We are planning to use 1769-L3 PLC with ASCII module as we are planning to communicate with Microcontroller , Barcode reader and Universal Temperature indicator. In 1769 PLC how many ASCII modules can be used? Pl. help me out as i want desired hardware configuration.
I don't see why you can't have at least two. Keep in mind that Port 0 on the PLC itself is an ASCII port itself.
We use it to send out print strings to our Wasp printers.
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
156
Like in the subject, I can't connect to the PLC, the Who active shows nothing just like RSLinx, you can see it in the attached picture. Its been...
1,675
Hello guys, I need to understand how instructions work in Square D Symax PLC. I need to upgrade old code which is in Square D symax SCP401...
2,363
831
647
