gjimgarner Member G Join Date Feb 2015 Location pennsylvania Posts 3 Mar 17, 2015 #1 what is the s: instruction in logix pro 500? newbie here
rdrast Lifetime Supporting Member Join Date Apr 2003 Location South Carolina Lowcountry Posts 5,544 Mar 17, 2015 #2 Instruction or memory location? If memory, I'd assume it holds the System bits.. things like the first scan bit, math overflows, and such.
duckman Member D Join Date Sep 2013 Location home Posts 302 Mar 17, 2015 #3 If you look at the project tree to the middle left, of the software you will see, 4th down below from "Help", "Processor status", click on that, then read all the help file about the topics it will be up
gjimgarner Member OP G Join Date Feb 2015 Location pennsylvania Posts 3 Mar 17, 2015 #5 thank you much
