S400 to L73 Ethernet Communication
May 2017
Regina
Hello,
I have two different PLC's. One being a 400 series siemens controller and the other is a L73 controller from RA. I am trying to communicate between the two using purely ethernet without any extra hardware. Is anyone able to aid me with this?
Thanks!
It's possible - Siemens have an application example here including documentation and code examples.
It will not be terribly straightforward though. If you really must do it with no additional hardware, then this is how it's done, but using a purpose-designed hardware solution will always end up cheaper. That is, unless the value of your labour is not figured into the calculation.
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,506
We all know that the S7-300 range has been around for an age and the new S7-1200 & S7-1500 ranges are well established any one know if the...
3,808
So I have a USB to PPI-RS485 Multi Master Cable 1P 6Es7 901-3D830-0XA0 SC-W7K81802 Is this the cable I can connect my Windows 7 machine with Step...
3,458
Hi I need your help I want know that how many stations(wincc,op panel ,..) can connect to a plc S7-400 cpu417. According Technical...
2,295
Hi all, Hardware: siemens S400 /profibus dp/ ET200s/ IM 151-1 Software: PC using Step7 v5.4 sp2 I'm trying to add more hardware onto an...
6,147
