hi
the problem is that everything is ok while we connect to plc and we can see the program pb,fb,ob,sb,db in the plc while online but when we try to open the blocks in the plc by block status section in step5 it gives a warning " 0321:AS Function Disabled :function active" and nothing happens it is not possible to open the blocks in this plc because we have no problem other s5 plc's.
Please answer me if you have any solution or idea about this problem.
thanks.
thanks.
