Anyone?
Any Suggestion
In Istack AF is cross marking
Can anyone help me?
Hello, Thanks for your reply.
How can i fix it?
Any idea?
I already disconnect 95U from machine. replce it another with another 95U machine is running.
Now i need to fix 95U.
Maybe something wrong with my hardware of 95U
i already check the bus.
any idea?
Overall reset your removed PLC - reload the program and try it in the machine again, carrying out cold restart.
If you still have BF fault return it to Siemens for checking or place it in the nearest waste bin!
How can i do a over all reset?
There is 10 Blocks in PLC and i cant delete them.
i try to remove battery but Blocks still there.
i am new in S5-95U. How can i remove this Blocks?
Is there an EPROM installed?
Remove Eprom, remove battery.
Replace Eprom, Replace battery and try again.
List the block numbers & type
Here is the Block
OB31
FB240
FB241
FB242
FB243
FB250
FB251
FB252
FB253
DB001
And i attached the s5d file
