Change Siemens S5-95U to S7 1214c problem
Citystars
Feb 2012
A Place
Hello,
My problem is i need to change a siemens S5 rig to a S7 1214c
The only problem i have is 2 things:
1) On the S5-95u there is a 8x analog input. How can i fix this? Cut the cable and use a analog module on the 1214c, thats the 8xRTDx16 bit (SM 1231RTD)?
2)This rig uses a high speed counter module for a position encoder. That uses a 15 pin connector. What do i need for the 1214c to get this signal?
A picture of the modules:
http://img692.imageshack.us/img692/5722/dsc03830vb.jpg
Hope you can help me
Thank you
The S5-95U had 8 channels of 0-10V inputs: you do NOT want an RTD module for the S7-1200, you want the 8 CH AI 8 card: 6ES7 231-4HF30-0XB0.
For the high speed encoder you can use the inputs on the 1214C CPU. Check voltages and encoder frequencies to make sure all is compatible. You'll need to fabricate the wiring connections to change from that 15 pin DSub. Pay attention to your grounding and shielding if the encoder wires are running any distance...
On my HMI (KTP1200), I've got this button "Generate Report", which generates a report (CSV) when it's pressed. (see pic) While it's being...
551
It might seem like a stupid question but please let me elaborate. I had a PLC that already had some IP address on it which I needed to change. My...
5,836
Hello Everybody, Recently we changed the gearbox which has different ratio than the original one on a motor which is controlled by Micromaster...
1,901
Hi! i'm just wondering did there is any chance to change Set Time(TV) on Siemens plc timer without step 7 using c# or python if timer not set in...
1,258
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,337
