S5 IM308B Upgrade
ThePortLion
Oct 2007
Ireland
58
Hi
I'm planning an upgrade from an S5 IM-308B profibus card to
an IM-308C.
I'm in the process of getting COM PROFIBUS software which
is used to configure the new IM-308C.
The IM-308B was configured using COM ET200 software and I have the hardware configuration file (.200 extension) but no COM ET200
software.
Obviously I need to know the original hardware configuration.
My query is, can i read this .200 file using COM PROFIBUS
or am I going to have to source ET200 software?
I believe is hard to come by.
Please post the 200-file, so will I see if I can shake some info out of it.
Kalle
Edit:
I am quite sure the ComProfibus cannot read your config file. And that you will need the .GSD/.GSE/or .200 type files for your profi slaves to be able to reconstruct the configuration file in ComProfibus.
And please check your p.m.
I got an error message when trying to open the file: 'Interner Fehler: Pufferlaenge nicht ausreichend'. Some buffer is too short. I can open other 200 files, but perhaps yours has a bigger configuration. ?
I'll have a look on the attic if my 1990' T5200 still is there, and if she is willing to spin up her old, squeeking Conner HD.
Kalle
Does someone have knowledge of older S5 network components? I have 944b cpu, and IM308B L2 bus. Parameters of L2 bus are stored at Eprom. Now I...
3,079
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
171
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
226
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
197
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
125
