S5 Instruction in FB
feniks
Jan 2008
Wrocław
29
Hello,
I am making conversion from S5 to SLC. I have only upload from PLC. Previous programer used function block FB120 and FB125.
Problem is that i don't know what this programs in fact are doing.
FB125 is called like that:
A I 32.6
JC FB 125
EING: I 32.7
ZIMP: I 64.7
ZAEH: C 36
WERT: KF +50
AUSG: F 36.1
ZEIT: T 37
KONS: KT 030.1
The body of FB125 consistes of instructions:
AN =EING
LW =KONS
SD =ZEIT
A =ZIMP
SSU =ZAEH
A =ZEIT
RD =ZAEH
L =ZAEH
LW =WERT
>=F
= =AUSG
So it means:
AN =I 32.7
LW =KT 030.1
SD =T 37
A =I 64.7
SSU =C 36
A =T 37
RD =C 36
L =C 36
LW =KF +50
>=F
= =F 36.1
I can't find out what SSU (something with counter) and RD (probably reset) means.
Can somebody help me?
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
90
I'm trying to dig to the source of a minor "recoverable" system fault throwing a fault light on a machine that has been confusing my operator...
113
122
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
128
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
306
