s5 print
vhg750115
Jun 2007
tlaxcala
Hi There, Somebody Knows How I Can Setting A Printer Like I Want Print My Archive, Because When I Open The Window Of Printer In The Espace Control Of Characters I Dont Konw What Write It.
Thank A Lot Of
I would suggest downloading the manual for Step 5 v7.1 (click here)
Section 14 deals with setting the printer parameters.
I tend to print to a file, then open this text document with word, edit it to fit neatly on A4 paper and print it out from within word.
To do this, in Step 5, select 'Documentation', then 'Step 5 Blocks', the program file used will be the program loaded, in the 'Block List' type 'A' for all (or whatever PB you want), select 'File', give the file a name and hit the output button.
Paul
Will someone please convert this logic to pdf?
142
Anyone have access to Melsec Medoc plus 2.31a that can either open a file (.pcd zipped in link below) and send a PDF/screenshot of the ladder, or...
388
I am working on a Markem X40 printer which uses NGPCL Commands and needs to send commands using a .net program. I need help with the following...
155
Hello, this is my first post after being a long time creeper on this forum. I am experiencing a fatal error any time I attempt to print to PDF...
400
I am stuck on a project. I am still somewhat green at PLC programming and had a project given to me to get at BROTHER printer to print via plc...
903
