S5 TNB instruction question
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all,
The TNB instruction in S5 transfers bytes from one location to another but I'm not sure which is the Src and which the Destination addresses.
If I had the following:
L (pointer to DB10.byte 0)
L (pointer to DB99.byte 0)
TNB 50
Are the 50 bytes going from DB 10 to DB 99 or is it going from DB 99 to DB 10 ??
I've looked at the manual but it says that the src and destination are Accu 2 which can't be right can it?!?
See manual attached...
Slogging my way through re-writing a Step 5 program in RS Logix, I have come across this segment: A F 60.7 A T 28 A I 3.4...
1,735
Hi all, I have read the manual section covering the S5 TNB instruction and realise that it copies a source datablock over to a destination...
2,348
I have a S5 115U CPU 943B. I have problem with S5 to S7 conversion. I don't know how to change LIR, TIR and TNB command. I've read in many forums...
4,787
I am working with a Siemens S5 115U 944 program. I have several questions, but probably the most frustrating so far is the following code. I have...
6,890
Hi all. Never really noticed, but I started double checking operands in the CPT instruction. I found if I have the expression N7[37,1] - N7[35,1]...
144
