S5 -> Wonderware 6.5 -> S7-400 CP434-5 Eth
gardener
Jun 2008
kiuhkin
Hello,
I have the following config:
several S5 PLC's on a Profibus FDL network connected to a PC with wonderware 6.5. Now I like to read back the tags from the S5 plc trough a ethernet connection in the PC into the S7 plc..
Because I dont have a S400 CP that's capable of FDL I would like to act the wonderware pc as a gateway.
Is this possible? I'v been reading something about DASIdirect server or S7 I/O server but since I'm not familiar with Wonderware I would like to ask some advice.
Maybe one of you sees another possibility?
Thank you very much
Tom
Hello, I wish to connect a Micrologix 1400 PLC with a Wonderware SCADA application. I have RSLinx Classic Lite. Is there any other way than...
1,198
Hello I work on wonderware intouch and s7-400 using CP 443-1 Using XP Virtual machine on Host win7-32 ultimate I follow all instruction using...
3,731
I did many SCADA projects using WINCC. This the first time using Wonderware My network is shown in attached file. and installed software on my...
1,290
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,414
Has anyone seen this problem with the Wonderware driver DASTCPCIP (Ver.4.0) to communicate with the new AB MicroLogix 1400 PLC? This is the same...
11,401
