Wonderware and S7-400
May 2007
giza
153
I did many SCADA projects using WINCC. This the first time using Wonderware
My network is shown in attached file. and installed software on my PCs also shown in the attached file.
Please need help in how to establish communication between PLCs and Intouch using Simatic.NET in details.
Appreciate your help
Your attachement does not work for me.
Is there a reason why you want to use Simatic-Net with Wonderware?
Whenever I've used Intouch together with a S7 controller, I've used the Wonderware I/O server for Siemens S7. The driver can be installed from the I/O server CD. The basic setup is done from the system management console.
Hello, I wish to connect a Micrologix 1400 PLC with a Wonderware SCADA application. I have RSLinx Classic Lite. Is there any other way than...
1,198
Hello I work on wonderware intouch and s7-400 using CP 443-1 Using XP Virtual machine on Host win7-32 ultimate I follow all instruction using...
3,730
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,414
Has anyone seen this problem with the Wonderware driver DASTCPCIP (Ver.4.0) to communicate with the new AB MicroLogix 1400 PLC? This is the same...
11,401
Hello, I have the following config: several S5 PLC's on a Profibus FDL network connected to a PC with wonderware 6.5. Now I like to read back...
2,892
