S7 1200 Analogue Out of range Alarms
bgeary
Jul 2008
Lincoln
Hi
I am trying to find out if and where TIA Portal V11 provides "out of range" alarm for analog inputs. Do they just appear in diagnostics? I would like to use a [Bool] to create an alarm in a DB.
Bob:sick:
With other Siemens PLCs I have had the problem that under/over range check generate an alarm if the signal is 3.99mA. The 0.01mA may not be because that there is a problem but just because the attached sensor can function a bit below its nominal range.
I ended up making my own check that generate an alarm if the signal goes below 3mA.
Dont know about S7-1200, but I would guess it works in the same way.
Just had a strange one on a 4 In 2 Out Siemens S7-1200 analogue module. I am used to seeing the status LEDs as green or red, but I haven't seen...
2,073
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
131
