S7-1200 and Chlorine and PH levels
DLMUK
Jun 2013
Southampton
311
I am designing a system for a swimming pool, I am looking for a chlorine sensor and pH level sensor.
Can anybody suggest sensors which can be connected to a S7-1200?
Is this a commercial size pool?
There are products specific for the pool industry. Most will have 4-20mA outputs. The biggest difference is cost and reliability... some chlorine sensors require a lot of calibration and maintenance.
I haven't done much in the pool segment but in water treatment, Prominent make some good products. I believe they also have gear specifically designed for swimming pools.
Otherwise, Evoqua (used to be Wallace & Tiernan) are very good but also expensive.
Or the Crius from Process Instruments. More cost effective, we had some issues the transmitters not being very robust, but i feel that was partly due to employing fat fisted Operators...
https://www.processinstruments.co.uk/instrument-controllers/crius/
Endress & Hauser are some of the most reliable I have ever come across, used them on many systems, compared to ABB & others I have come across they out perform & reliability is second to none. In one plant we had over 200 instruments from conductivity to level & pressure a number of them were of other makes, due to a number of failures we replaced them with E&H, as far as I can remember we only had 3 failures over a 20 year period of the E&H, two of those were due to corrosion of the terminals (very hot, wet & corrosive environment) the other was a board failure.
Just a thought.... have you thought about changing over to a salt system?, I did and will never go back, its a lot cheaper, its so much better for your skin and easy to maintain
Not a bad question...
It uses the salt through an a cell and generates the chlorine
Some reading material https://www.hayward-pool.com/shop/en/pools/salt-water-chlorination
The main things is keep the PPM around 4000, I use about 15 bags of salt when I open the pool in the spring and a few during the summer, I tied the control panel power to my timer so it would only run when the filters were running, its a low level of salt and a low level of chlorine so easy on the skin and eyes
Edit I also found the water clarity was better... nothing like diving into a pool that was perfect
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
34
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
284
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
135
