S7-1200 Clear Ethernet Buffer
Jonnie_R
Feb 2012
Brecon
216
Hello,
I am using an S7-1200 with a Moxa N5250A to read data from a weigh scale, but occasionally the scale will send a couple of frames of data after I cancel the weight reading.
Is there any way to clear the Ethernet buffer, or do I just have to let the receive block complete to empty the data?
Thanks,
Jon
You can use block_move to zero buffer or copy data only from buffer if read was succesful.
Thanks for the reply. I already only do certain actions when the TRCV_C block .DONE output is activated, as I need to extract the weight from the CHAR array by converting it to a string etc.
I'll just leave the TRCV block enabled continuously and ignore any unwanted data.
Hello! How can I clear (delete, write zeros, false) a DB in TIA V11 SP2 Upd5, CPU 1214C, if the size of the DB is NOT known? More exactly I...
4,674
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
34
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
283
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
