s7-1200 compatibility
jairus
Aug 2010
Busay Cebu City
47
Dear Experts,
Next project I'm planning to use S7-1200 plc's. Pls. advice me if these modules i list below are totally compatible to the CPU 1214C (release 2014), specially the digital modules which was released in catalog 2013, do they are 100% compatible to CPU1214C which was released in catalog 2014? because i cannot find these 2 digital modules in catalog 2014.
Thank you so much. Any related answer is really appreciated.
1. CPU1214C (6ES7214-1BG40-0XB0) (catalog 2014)
2. SM 1221 DI 16X 24DC (6ES7221-1BH32-0XB0) (catalog 2013)---digital module
3. SM 1222 DQ 16XRELAY (6ES7222-1HH32-0XB0) (catalog 2013)----digital module
4. SB 1231 THERMOCOUPLE SIGNAL BOARD (catalog 2014)
5. SIMATIC HMI KTP400 BASIC (6AV 2123-2DB03-0AX0)
6. STEP 7 PROFESSIONAL V13 FLOATING LICENCE
I think a lot of the cost will be the:
I think you can get away with using the Basic version, the only bit I don't know about is the HMI, but as it is called Basic... In the UK the Pro version is about 4 times the cost of the Basic version.
The previous quotation with all modules + STEP 7 PROFESSIONAL V13, if you convert to Euro that would cost 3073 euro, now the new quotation with step 7 basic v13 + modules it only cost 1345 euro. The figures is really really drop...
Anyway i only use Step 7 V13 (TIA portal) when it comes to S7-1200. but when it comes to s7-300, i still use the Step 7 v5.5 sp2...
Thank you so much for all your info's, it's really appreciated.
So I've got a 1762-L40bwar Micrologix 1200 PLC. I'm looking to incorporate atleast 2 analog sensors into my project (conductivity and pH) and I am...
2,666
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
61
37
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
288
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
107
