S7-1200 cut list data exchange
fons04
Nov 2007
Quebec
69
Hello, we have a servo saw with an siemens plc s7-1200, a comfort panel 12 inches, we want to import data from excel files on a server with a bar code already existing on these files and display these excel sheet in a similar format to the screen, the factory uses Epicor as ERP software, what you advise to exchange the data, is opc is a good idea, does Epicor support opc? Should i use the recipes in tia portal to display cutting list on hmi? As this project is new to us, your experience would be profitable and appreciated. Thanks
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
51
30
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
266
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
123
