S7 1200 ethernet connection
rQx
Oct 2010
Trelleborg
1,051
Hi!
I'm fooling around with the s7 1200 to learn how to setup a ethernet connection between two CPUs. I've succesfully made a link and I can recieve and send a word between the two CPUs. What I can't figure out however is how to send more then one word.
What I do now is sending Mw100 from CPU1 to Mw10 on CPU2. I have entered MW100 as DATA on the SEND block and MW10 as DATA on the recieve block.
What I want to do is send the following
CPU1 CPU2
MW1000 MW100
MW100 MW10
MW10 MW1
How do I configure this?
If you figure it out I would like to know.. what did you do to pass the one word? I have not tried it but will next week
Presume your using TSEND and TRCV ?
Here's an example from Siemens for clock sync over ethernet for 1200's using TSEND/TRCV
If your new to the 1200 there is a nice easy book guide here (needs siemens login (have to register))
Yes Im using TSEND and TRCV. I have managed to sent data blocks now, got some help on the siemens support forum. I had no idea I had to do a struct in the data block. My new problem is that you can't insert strings in the struct. I can send a string seperatly between send and rcv but not within the struct of my data block. Any suggestions?
Is there a way to have two send blocks and two receive blocks working together?
TSEND1 working with TRCV1
TSEND2 working with TRCV2
TSEND1 shall not send to TRCV2
it is the same IP so I don't know how to.
Send it through a Datablock.
Place a struct in your datablock and insert the data to be sent there , then In the TSEND and TRCV DATA input write: "datablockname".structname
So I have finally had to bite the bullet and do some modifications to some Siemens PLC code written in TIA. I have got both V10.5 and V11...
4,760
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
183
Hello all. I have a future project planned with a leibinger jet3up inkjet printer that I will have to send the print details to the printer via...
1,233
Hi, What is the easiest way to create a Watchdog between 2pcs S7-1200 over Ethernet?
1,521
Hello all, I am working on a project utilizing an s7-1200 cpu and Tia Portal v17. I currently have an external PCB with some sensors on it (and...
736
