S7-1200 first time IP assignment problem
Yashka
Nov 2019
WV
91
Hi All
Could anyone please explain to me why TIA didn't fill the right field by known MAC? As I understand from various videos and tutorials it must be automatic. This field can't be filled by hand, unfortunately.
Thanks in advance!
This is very strange. It should have been detected automatically.
I recommend you download the Profinet Commander tool which has a free version that supports DCP (Device basic Configuration Protocol) client functionality just to make sure that your PC's interface is communicating with the S7-1200. DCP does not require IP setting on the DCP server's (in this case the S7-1200's) side.
Thank you! It did help!
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
43
26
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
261
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
83
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
