S7-1200 locked out by password
mcmoney
Jul 2015
santiago
Hello I am relatively new to PLC programming and even newer to siemens. Our company purchased 4 concrete batch plants which came complete with S7-1200 hardware and a PC used for HMI. I have had not been able to access the program on the PC which is locked by an O-key USB dongle and the manufacturer is no help. I have V11 TIA portal on my lap top and when I try and download the program connected direct to the PLC I am again locked out by password.
I really need to at least view the program for troubleshooting purposes and even better would be the ability to edit.
Does anybody know a simple method around this. Please help!
You have to contact the original manufacturer and ask them for the program and password.
That said, IMO if this is a standard product from the vendor, then it should be so well-documented, debugged and with so much integral diagnostics that it should not be necessary for an end-customer to look into the code for troubleshooting.
If these machines are still under warranty the manufacturer may not want you connecting to the machine for any reason.
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
34
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
283
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
134
