S7-1200 multi-dimensional lookup table
marko18
Nov 2021
USA
47
Hello all,
I am working on a project with an s7-1200 and I am controlling three stepper motors using this controller. I will be receiving input data from an external sensor, and using this data to jog the three stepper motors to pre-determined positions. I have all the possible positions in an excel file lookup table.
The issue with this lookup table is it has two inputs and three outputs (temperature and pressure are inputs, and for each combination of temperature/pressure, the table has a motor position for each of the three motors.) The possible motor positions were found via simulation and do not have any mathematical equations that tie them to the inputs. I was wondering if implementing this lookup table would be possible with the s7-1200, and if so what is the easiest way?
Yes, quite easy.
The S7-1200 can utilize SCL and multi dimensional arrays. Which makes this kind of work fairly straight forward.
Yes, quite easy.
I see. So I would have to use SCL? I've only used ladder and am not even very experienced with that. Is there a way I can import the excel file with SCL or just have it read the file automatically? There are 1000+ entries
how many input dimensions per motor? It sounds like 2 (temperature and pressure).
are the ranges for each input constant across the table? E.g. do the data in one motor's eXcel worksheet have a header row with cells like "0<P(ressure)<=10," "10<P<=25," "25<P<50," etc., and another column down the left with cells like "32<T(emperature)<=40," "40<T<45," etc., and then all the values at each row an column inside those headers are the motor positions?
To get the data in and out, you can use csv files. See this for ideas, and if you have HMI capable of recipe management, that would also be a way to go.
DOES ANY ONE KNOW WHAT i WOULD NEED TO CONNECT 2 HMI'S TO A MICRO 1200?? MY CURRENT SYSTEM IS A MICRO 1200 WITH A PANEL MOUNTED PV550 TOUCH...
3,515
2,232
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
257
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
