s7 1200 nil ptr
May 2006
huddersfield
67
Hi can anybody advise
i have been doing a program using s7 1200 (first one)and have been downloading testing modyfy for a few days all ok.Now it will not go into run when i try to put it in run the fault light flashes.in the diagnostics buffer it says nil ptr in ob1??? any ideas what this means and how to sort it
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
58
35
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
285
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
100
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
135
